200SX shutting off
SGT
11-15-2004, 11:01 AM
I have a 96 Nissan 200sx and I cannot figure out what is wrong with it. If I am not pressing the gas pedal the car sometimes shuts off. The RPMS will lower really quick and the car stalls. If the car is about to stall, I can slam on the gas and usually revive it if I do it fast enough. I have replaced several parts like the fuel pump, alternator with no change. While idling at a red light, I find myself pressing both the break and gas pedals just to make sure it will not stall. I have taken my car to several mechanics and they just want to guess at it and change everything under the hood instead of actually figuring out what's wrong. Any help would be appreciated.
logik23
11-15-2004, 01:39 PM
If this is the FWD Sentra version of the 200SX, get the hell out. If it's the non-USDM RWD 200SX, then sound like your timing is off.
Also, it's RPM, not RPMS, even plural.
SGT
11-16-2004, 08:02 AM
I don't think it has anything to do with timing because it's not a constant thing?
logik23
11-16-2004, 01:49 PM
Sometimes, when the timing is a little off, you'll get a rough idle, it might even stall at idle, but the rest of the time it's fine.
SHIFT_KA24DE
11-16-2004, 02:07 PM
yea my s13 has the same problem.. but it only happens when the heater is on. The idle drops and occasionally will die out...
pretty disgusted by it since it never happened before... but then again it's only been 3 months since i got the car...
Nismodude542
11-16-2004, 02:54 PM
check your vacuum line
Nismodude542
11-16-2004, 02:55 PM
on the intake...
SGT
11-17-2004, 09:14 AM
The vacuum line seemed just fine. As for the idle, I never really have a rough idle; it goes from perfect to 0 in one drop of the needle. Seems to be a mystery... I appreciate the help, if you all have any more idea please let me know. Thanks!
SHO411
11-17-2004, 10:29 AM
try replacing your Throttle Position Sensor, if this is off or bad, it has a broblem iddling. And yes, double check on the vacum lines.
