S10 Starting problem-lemme explain
Here's what happened, Vehicle just stopped working. My brother & his buddy (a certified mechanic). They replaced the blackened, goo stuffed fuel filter. then when we tried to restart we noticed something flowing from BF on the throttle body, that was gasoline, after siphoning we also removed spark 1 & found gas gushing from it as well. we lost about a gallon in that instance, and then some after that. after some brianstorming we accidentally figured out that fuel injectors need not only a blue O-ring but a small black one as well called the "lower injector O-ring". we got a kit & replaced it (all four upper & lower), serious flooding stopped. now truck won't turn, we blow about 1-3 fireballs out of the TB, with BF closed & in Flood clear (BF open) but no engine turn. I need assist in getting an idea of what could be causing this not to turn. we hooked up a computer but no codes were returned (Key on, Engine Off).
We need ideas (cheap) if possible to get this thing back on the road. My bro keeps going back to timing, wanna make sure that we exhaust everthing else first. we have spark & constant fuel.
Please help.
-Nuttin But Problems-
'96 S10 P/U:2.2L MFI:5sp:4x2:LB:Rhino Lining:99k mi
-also-
'02 Dodge Grand Caravan Sport:3.3l:FWD:Stock 51k mi.
