86 civic 1.5 carb,surging?
mttfisher
11-14-2004, 02:52 PM
ok the car idels fine but mostly in lower gears it stalles like it's not getting enougf fuel and sometimes on the freeway it cuts out and when I push down on the gas pedal it picks back up after a few seconds.I have replaced both fuel filters,airfilter,PCV,spark plugs,wires,dist.cap,roter.????
lxndr
11-14-2004, 04:49 PM
Sounds like a bad fuel pump or a bad carburetor. I'd start by checking for vaccuum leaks, then check the fuel pressure. If you can't find any problems then it's time to rebuild the carb.
revhalzoo
11-21-2004, 08:19 AM
yeah sounds like a bad float in the carb, or a vaccume leak
mttfisher
11-30-2004, 12:26 AM
yeah,rebuilt the carb. and found 2 vacuum leaks along the way runs great now,thanks
badazzrx7
01-05-2005, 01:33 AM
well what about the timing and the distrubitior...is it positioned correctly!!! that could cause alot of that also!!! it did with mine and i did all the things you did too
