11-13-2004, 08:57 AM
1999 ZR2 fuel pump whine????
I changed out my fuel pump a few days ago because when I turned the key on there wasnt that few seconds whine of the fuel pump...so.....I changed out the fuel pump......still no power to it.....so I found the relay under the hood in the box and swithed out the relays....still nothin.....so I slammed the hood and was giveing up on it,but.....I thought I would try once more....turned the key....heard the whine it started......this was a few days ago.....now...I got about 30 mile4s from home...same thing. Fuel pump isnt coming on.....
Any Ideas????????
11-13-2004, 09:50 PM
Banned
Re: 1999 ZR2 fuel pump whine????
try wiggling all the wires under the relay and see if that helps. It just sounds like a loose conection somewhere under the hood
11-13-2004, 10:23 PM
Re: Re: 1999 ZR2 fuel pump whine????
Thanks...I will give that a shot...I forgot to add.....I checked the voltage at the connector wrer it plugs into the pump.....I'm getting 12v for a bout 2-3 seconds when I turn the key on...then it goes to 0...I assume the is the charge up voltage.....but still wont come on. And...I hooked up the old pump straight to a battery and it works.....so..I pluged it up and turned they key on and it wont run either...so..I will give the wingleing a try...
Thanks for response.....
11-14-2004, 12:33 AM
AF -Advisor
That is the prime voltage.
It primes the pump for two seconds and then shuts off.
1995 Factory Blazer Service Manual for sale, PM if interested.
11-14-2004, 02:50 AM
sounds like a bad connection if you can hard wire it and it pumps, check the connections
11-14-2004, 07:31 AM
do you have an alarm. some alarms shut off the ecm power while others just stop the starter from turning. my wifes 1999 taurus shuts off the ecm.
11-14-2004, 07:32 AM
So whats the easiest way to hard wire it?? And if its getting voltage power to prime..why isnt it priming?? Sorry...first time dealing with pumps on a S-10..
11-14-2004, 07:40 AM
No...I dont have a alarm....but I was reading something about pass lock?? Something about if I have the wrong key?? But my key doesnt have a chip in it...And I been using the same key for 3 years now....
11-14-2004, 12:29 PM
AF -Advisor
How much fuel do you have in the tank.
From what I have heard, you have to have it up to a certain level in the tank to prime it for the first time.
11-14-2004, 12:41 PM
I had just put about 10 gallons in it....I have been driving it for about a week now since I put the new pump in...Its beyond me....I have tryed everything...
Thanks for the responses
11-14-2004, 03:08 PM
your pass lock is the problem.
11-14-2004, 03:12 PM
are you saying you have pass lock or you dont know? i cant remember the exact name of the system. maybe one of the other guys would know.
11-14-2004, 03:39 PM
I'm not for sure...its in the manual....how do you reset it??
11-14-2004, 04:17 PM
i dont think you can reset it. you might have to bypass it.
11-14-2004, 06:03 PM
Well....same story again...I was about to give up on it...tryed it once more....turned the key....pump charged up..it started...now my gage doesnt work...and when I started it it had a REALLY bad ticking....And there was alot of condensation coming out of the tailpipe...but... I let it run for awhile and the ticking went away.....I dont have a clue what is wrong with this thing...BTW..I have a sevice engine light on now....
Thanks again for the responses
