Build up of RS/GS 95 engine before putting on the turbo list?Lahardbodie 11-13-2004, 01:35 AM Hey guys I saw a post a few weeks ago about something I was hoping to get some more details on. If you have a 95-99 rs/gs BEOFRE putting installing a turbo kit someone listed a few internal spec mods (i'm not talking about a cold air intake and headers type sh#t) I mean actual head and internal engine work that would possibly bring the horespower up to around 200 that way when you do install a turbo kit it kicks in on top of a lot more horsepower from what I think the person called a more naturally aspirated engine which I guess means more built up. Anyways if anyone could give me this basic list I'd appreciate it. thanks, LA. P>S And if you actually went and built up your engine with the things on that list would you be able to go with a bigger turbo then say the HRC Stage 2 or would it still not be advisable to use a bigger turbo system then that on a 420a motor even with the upgrades? (im referring to the HRC 2 turbo system as its the only one I'm aware of that you can put on the 420a motor without having to do your engine internals) coolguycooz 11-13-2004, 01:59 AM no NAturaly Asperated means that its non turbo. And the reason you would build up the engine before the turbo not so you get a more hp head start but because you dont want to blow your engine up. You build it up so you can support more boost more boost= more hp and its not all about boost its all about the flow. how fast your engine can handle it. so yeah good luck with that. Automotive Network, Inc., Copyright ©2012
