Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 11-12-2004, 10:16 PM   #1
PoopyBritches
PoopyBritches Normal reputation
Unhappy 89 S10 Muffler Exploded
Been having a strange problem with it all summer. Typically what occurs is a sudden loss of power accompanied by a hissing sound. Letting off the gas a couple of seconds usually returns it to normal. Today, accellerating from stop light, sudden loss of power and BOOM like dynamite, muffler exploded.
Any ideas? I'm gonna tear into it tomarrow and see. Hard to troubleshoot since it occurs at random usually once every 10 to 40 miles travelled.
PoopyBritches is offline   Reply With Quote
Old 11-13-2004, 01:27 AM   #2
OverBoardProject
Banned
OverBoardProject Normal reputation
Re: 89 S10 Muffler Exploded
Well I can only guess that the bushings in your distributer are worn out, causing the truck to go out of time. Or it could be the vacume advance, also part of the distributer
Good luck
OverBoardProject is offline   Reply With Quote
Old 11-13-2004, 10:20 AM   #3
JMorales
JMorales Normal reputation
I had the same problem with the loss of power and the hissing. It turned out to be a clogged catalytic converter causing the loss of power, and the hissing was from the exhaust trying to go somewhere else.
I had my whole exhaust replaced and you could not believe the performance now since it is able to exhale.
J
JMorales is offline   Reply With Quote
Old 11-13-2004, 02:43 PM   #4
CW_racefan
CW_racefan Normal reputation
I think JMorales is probably right on. Catalytic converter is probably toast. Part of the guts of it were probably rattling around, occasionally plugging the exhaust, then finally your muffler just let loose.
CW_racefan is offline   Reply With Quote
Old 11-13-2004, 02:48 PM   #5
BlazerLT
AF -Advisor
BlazerLT's Avatar
BlazerLT Normal reputation
Re: Re: 89 S10 Muffler Exploded
Good luck
He is talking about his exhaust.
Loss of power can be from a plugged muffler and/or cat convertor.
Seeing that it exploded, I think the muffler was indeed the cause of the performance loss.
If the engine can not breat it will kick itself out pretty quickly.
1995 Factory Blazer Service Manual for sale, PM if interested.
BlazerLT is offline   Reply With Quote
Old 11-13-2004, 03:57 PM   #6
PoopyBritches
I found a vacuum hose that was torn. Coil is loose, hmmm maybe bad ground or is it juz play inside the bracket... dunno yet, can't c it since its mounted in tight spot along side of engine. Engine is getting some missfire in it so I'm changing Dist cap/rotor, plugs and wires... its overdue. Going to Muffler shop Monday for muffler and convertor. Thanx 4 ideas. Let u know what happens.
Old 11-17-2004, 10:13 PM   #7
OverBoardProject
Banned
Well BlazerLt I guess that you've never seen an engine out of time enough where the gas builds up in the exhaust. I have, and it's often caused by a worn out set of bushings on the distributer.
Then it only takes 1 little spark in the muffler to cause an explosion which will blow the muffler out.
Old 12-19-2004, 10:15 AM   #8
PoopyBritches
Replaced Complete Distributor, wires, plugs, Catalytic converter and muffler. Set timing. So far ok, but haven't driven much.
Old 12-19-2004, 01:55 PM   #9
NYGIANT_fan
NYGIANT_fan Normal reputation
Can you tell me where the oil filter is on these 1989 s-10 blazers???
Thanks!
redskins_fan_2005@yahoo.com
NYGIANT_fan is offline   Reply With Quote
Bookmarks
Google
Web AF
