quick question.
Hodo
11-12-2004, 05:10 PM
Whats the propper Tire pressure on a Z32 NA with stock wheels?
My car doesnt have that info ANYWHERE in it or on it.
Its kinda funny how the little things are always over looked.
ZedEx
11-12-2004, 05:51 PM
Its not on the door sill?
... Hmmm... www.Google.com it :D
-Wes
Hodo
11-12-2004, 05:53 PM
nope.... tried gives me 140K+ hits...... none of the first 20 are even close.
ZedEx
11-12-2004, 05:55 PM
Damn... Let me do some searching for ya'
-Wes
freakonaleash1187
11-12-2004, 07:16 PM
well, as a general rule of thumb i always just put 35 psi in there.
-Jared
ZedEx
11-12-2004, 07:36 PM
Helllllll NO!
35psi is what most tires maximum capacity is... That ruins the integrity of the tire if it gets pushed too hard... Then your riding on alloy heading into a ditch.
I would say no more than 30psi front, 32-35psi rear... But check before you mess with it!
-Wes
neogenesis
11-12-2004, 09:25 PM
Doesn't it say under your center compartment? I know mine does ('90 TT). But my tires aren't stock, I don't think the previous owner replaced them with the same exact tires. What should be a good psi if the tire max for the front is 38psi and the rear is 44psi. Does 34-35psi and 40psi respectivly sound good?
ZedEx
11-12-2004, 09:29 PM
Should be... Damn those are some tough ass tires dude.
Run a few PSI under... Should be ok.
-Wes
Hodo
11-12-2004, 10:58 PM
I ran my ZX2 on the road with 32PSI, and on the track with 36PSI front and rear. Some times I would drop it down to 28PSI depending on the course conditions.
I will run these at about 32PSI then... seems like a safe number.
E Honda
11-13-2004, 01:41 AM
When all else fails ......look at the sidewall of the tire. :2cents:
k3smostwanted
11-13-2004, 03:18 AM
i dont think i have the stock tires on my Z but my max is 44psi. i usually keep about 38-42psi in them. my nittos 555's max was 52psi but usually kept about 46-48psi. not that it matters, they dont hold up to curbs to well. ill tell you that much.
BTW: i have michelin pilots or something like that.
