87-89 nissan pulsar nx se motor in 240?
SilviaLuva
11-12-2004, 01:28 AM
i gotta 89 240sx with da sohc and i wanna put the ca18de motor in the cheapest i can. the pulsar nx has the ca18de motor but its fwd is there any modifications i need to do to put it in the 240 or is it jus changing the tranny?
SHIFT_KA24DE
11-12-2004, 08:10 AM
FF drivetrain cars have the engine aligned sideways compared to FR which have them straight in the engine bay. This is due to the existence of a driveshaft in the FR. I highly doubt the the money it'll cost you to do all that will be worth putting a non-turbo 1.8 litre into a 240... instead of a 2.4 sohc. You could be better off w/ the ka24e...
dunno that's my 2 cents. nice car tho.. g luck.
Hit_N_Run-player
11-12-2004, 09:37 AM
just try and pick up a ka24de for a few hundred dollers from like a salvage yard or something...
sRscooby
11-12-2004, 11:54 AM
why not just get the ca18det from ebay, they go for pretty decent prices, ~$900-$1200 dollars for a front clip, even cheaper for the motorset if you dont need the extra stuff, the swap isn't that hard
SilviaLuva
11-12-2004, 02:43 PM
i know u jus cant directly bolt it in
is the rwd tranny a direct bolt on or is there fabrication to turn it side ways or do i jus have to buy motor mounts
SilviaLuva
11-12-2004, 02:44 PM
the reason i dont go wit kade is i wanna make it as much silvia as i can
sRscooby
11-12-2004, 03:56 PM
umm, then why are you getting the ca18de... you want the ca18det which was in the 89-90 silvia... RWD already, don't waste your time on fabrication of a FWD engine when there is a RWD version...
Hit_N_Run-player
11-12-2004, 05:52 PM
i still think this is the best idea for you, do some research in your city on much you could pick one of these up for....
SilviaLuva
11-12-2004, 11:06 PM
in the s13 they came wit 3 models k q j the k model came wit the ca18det the q and j came wit the ca18de thats wat i want then ill drop a turbo on when i hook up the na first
sRscooby
11-13-2004, 08:17 AM
well then, get the ca18de from a silvia then, not a pulsar
