2002 Toyota Camry Air Filter
iceman1234
11-10-2004, 09:24 PM
I am trying to replace the air filter on my car. I know where the filter goes but I just dont know how get the cover off in the car to replace the filter. Please help me... Any help would be appreciated.
Thank you so much
camryle2001
11-11-2004, 10:36 PM
I changed air filter on my 2001 just yesterday. Standing on the driver side of the car and looking into the hood I see two clips on the air filter housing. Once those are removed, the filter cover just needs to be lifted up. 2002 may be different though.
ToyotaTech
11-12-2004, 10:04 AM
on yours u have 2 unbolt the airbox there are 2 10mm bolts on either side of the box
hy007
01-09-2005, 02:24 PM
I could get to the 2 bolts, but I still wonder if I can use more force to lift the filter cover without damaging other connectors. It seems awfully tight, and though I can see part of the filter, I cannot pull it out..
hy007
01-10-2005, 08:22 AM
Once you unscrew the bolts, you still need to "unhinge" the the left corners in order to open the cover. Then you will slide out the air filter towards you. I was initially unable to slide the filter out due to the fact that I did not unhinge at the left corners and was pulling on the wire sensors.
hontoy
01-10-2005, 04:11 PM
Thank you so much
SEEN MY GRANDMA REPLACING HER 2000 CAMRY AIR FILTER THE OTHER DAY.
