Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Ford > Contour
Old 11-10-2004, 01:33 PM   #1
hetherp8157
hetherp8157 Normal reputation
Angry Problems with Cold Start- Trans or Engine?
I have a 98 Ford Contour 6 cyl. 104,500 miles. Each winter or beginning of the cold season I have the same problem.
I start the car, (starts fine), let it warm up. As soon as I drive to the end of my block and make my first complete full stop. The car tachometer drops a bit, then the engine revs high and then it falls back into place. I tend to ride my car throughout my neighborhood making approximately 4 full stops before the car is completely warmed up and ready to go. Then it seems fine.This morning, It dropped to just above 0 then up high and back to normal, the worst drop/rev it has ever done.
Is this the transmission/the engine? Nothing ever comes up on scans and it is only happening when the car/engine etc. is cold and has been sitting for several hours.
Its driving me CRAZY
hetherp8157 is offline   Reply With Quote
Old 11-10-2004, 03:46 PM   #2
beyondloadedSE
AF Ford Contour-Advisor
beyondloadedSE's Avatar
beyondloadedSE Normal reputation
Id replace the fuel filter. Mine used to do the same thing.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
beyondloadedSE is offline   Reply With Quote
Old 11-10-2004, 03:55 PM   #3
hetherp8157
A Fuel Filter would cause such significant problems?
I think I had it replaced a while ago- but I will look into it. It doesnt sound like transmission problems to you?
Old 11-10-2004, 05:58 PM   #4
beyondloadedSE
Re: Problems with Cold Start- Trans or Engine?
5 speed or automatic?
"The CEG Nazi"
www.contour.org
Old 11-10-2004, 09:13 PM   #5
hetherp8157
Automatic.
It has been a problem every cold season since I got the car. Today was the first time it was so severe I thought the car would stall.
Thanks!
Old 11-11-2004, 09:28 AM   #6
beyondloadedSE
hmm...the automatic transmission complicates things then. If it was a 5 speed its highly unlikely it would be that. Does it go away after the car warms up?
"The CEG Nazi"
www.contour.org
Old 11-11-2004, 10:44 AM   #7
hetherp8157
It does go away once the car is warmed up and I have driven it and worked out the kinks.
I am planning on taking it in to get looked at, but I want to have an idea of things so i dont spend a lot of unnecessary money.Thanks for your help!!
Old 11-11-2004, 12:46 PM   #8
beyondloadedSE
Ok, it doesnt sound like a transmission problem to me then. Try replacing the IAC valve and see if that doesnt help.
"The CEG Nazi"
www.contour.org
Bookmarks
Google
Web AF
