Suspension lift question
RticQl8
02-23-2002, 02:00 PM
I have a calmini lift on order but im thinking of making changes to the kit. I realy want to use revolver shackle to increase rear wheel travel. Problem is revolver shackles require longer shocks. The only place I could find revolvers for sale does not specifiy which shocks to use.
http://www.4x4parts.com/public_html/shop/?page=shop/flypage&product_id=134&category_id=14c5eebe912010bb20f52d3dc7fd5b3f&ps_session=53eafad9b435b65f876768bf8311ef6e
So if I go with these shackles and the calmini kit I will have an extra set of shocks laying around = waisted money.. Also the lift provided by the revolvers is slightly less than the lift provided by the calmini shackles. Is there a way to make up the difference? I dont want a saggy bottom
wqbang
02-23-2002, 09:16 PM
Call AC. I am sure they have the part numbers you are looking for.
As for the Calmini lift, I am pretty sure that I read that it offers no additional wheel travel in the front, unlike the AC and SLR upper A-Arms do. Keeping this in mind, after putting in the revolvers your rear wheel travel is going to be well more than double your front. Having such unbalanced travel could end up being a liability. Plus keep in mind you will need to replace your rear diff breather tube and extend your rear brake lines.
XSAL
02-23-2002, 10:20 PM
Just curious. Does anyone know if Calmini made any changes to the front a-arms after a magezine commented (I believe it was some 4x4 magazine that said so in an article) that Calmini does not offer additional wheel travel?
I just can't imagine a company like Calmini would just leave something like that unchanged after the negative (relatively) comments were made. I would think that many people who are planning to install 3" lift want the additional wheel travel after spending some money on it.
Or, have anyone seen/heard if Calmini said anything regarding to the comment made on the magazine?
Again, I'm just curious to find out....since I am also strongly considering purchasing Calmini's front a-arms....
Thanks,
RticQl8
02-23-2002, 10:24 PM
According to Calmini (dont remember the exact #'s) their lift will increase front wheel travel more than 2". If it where not for this I would have bought another lift kit. I will double check on monday just to be sure but I know I went over this with them already. Im aware of all the messy crap associated with installing the revolver shackles but I realy realy want them so ill try realy realy hard to install them :p
FSRBIKER
02-23-2002, 11:34 PM
The magazine was 4WD and Sport Utility, the August issue...interesting though that comment does not appear in the on line version of the article. The comment was something along the lines of "With the lift installed we were able to install larger tires but no increase in wheel travel was seen"...I have to look as I think I have that issue somewhere still.
RticQl8
02-24-2002, 03:39 AM
If you could please locate that article I will ask Calmini about it monday. If there lift doesn't provide 2+ inches of increased wheel travel I will have to go with another kit. Sucks to because I've realy taken a likeing to Calmini. Best company I've ever had the pleasure of dealing with.
Schludwiller
02-24-2002, 03:04 PM
And please post what you find out. It would be nice to get to the bottom of this. Whether they've made a change, or if not why, etc.
RticQl8
02-24-2002, 04:33 PM
I was looking at the SLR kits today and they claim to have .5" more wheel travel front and back in their stage 3 kit over their stages 1 and 2. I can't figure how the only difference from stage 2 to 3 is the addition of the front torsion bars. Any ideas how this would affect rear wheel travel?
warmonger
02-24-2002, 05:19 PM
The stage 3 kit includes a National Spring spring pack. That is where the travel comes from.
Stormy
02-24-2002, 07:24 PM
Thanks,
Wait, can someone explain to me how the calmini lift doesn't add travel? Are we talking front travel, rear travel, or the average of the front and rear? The only way that I can see it not adding travel is if it adds some sort of limit on the up travel. The bumpstop is going to be the same on the down travel (I would think).
RticQl8
02-24-2002, 10:05 PM
Actualy the spring pack comes with both the stage 2 and 3 kits according to. http://www.spencerlowracing.com/suspension.htm and even if it didn't that wouldn't explain the added wheel travel up front
warmonger
02-25-2002, 01:14 AM
I misunderstood your question. I thought you were referring to rear. My guess would be that the front is gained via the bumpstop replacement in combination with the high-angle ball joints and control arm. I haven't really reviewed the differences between the Stage 2 and 3 kits since I have to have the leaf pack because of my rear locker. That pretty much sewed up my choice. You might want to call Spence and ask him. He will talk to you if you ask questions.
RticQl8
02-25-2002, 01:21 AM
After reading my post I can see how I confused you. What I meant to say is that SRL shows incresed wheel travel from stage 2 to stage 3 however the only added componet is the torsion bars. Maybe a call to spencer is the best solution but I can't afford their kits anyway so ill probably just let it go.
xoc
02-25-2002, 02:53 AM
??? :confused: What ?
OffroadX
02-25-2002, 10:04 AM
More prone to axle wrap/hop I'd say...
Brent
warmonger
02-25-2002, 11:58 AM
Ian,
In sand the factory leaves have atrocious axle wrap. The spring pack uses a double-wrapped eyelet that will generally eliminate it in all but high hp applications. The locker and tires brought it out big time. It's either that or I add a ladder bar setup that no one makes. It is easier to just replace the spring pack than fab a ladder bar myself.
