Blower only works on high ??ms5star 11-08-2004, 09:05 PM Hello everyone, I'll just thank everyone now who takes the time to anwer my question...Anyway..my blower fan will only work on high.. at least it's working...but Iwas told by the dealer that it is the relay..Does this sound correct? and if so, do i pull the panel out to get at this relay..is it right behind the actual lever where you choose which speed?? Ironic 11-08-2004, 10:26 PM Try some electrical contact cleaner on the switch itself be4 goin into the relay thing. Spray the switch up good while you work the switch through its full range- may be all thats needed. ms5star 11-08-2004, 11:17 PM Try some electrical contact cleaner on the switch itself be4 goin into the relay thing. Spray the switch up good while you work the switch through its full range- may be all thats needed. O.K .. I will try that 1st... Thank You. hundahunta 11-09-2004, 03:38 AM you probalby need a blower motor resistor ms5star 11-09-2004, 10:36 PM O.K .. I will try that 1st... Thank You. O.k, I sprayed the contact stuff and played with it while doing so... But still nothing.. Now, is this resistor thing in or near the glovey...Is it easy to get at??? hundahunta 11-10-2004, 12:13 AM on the pass front side fire wall it is located under the kick cover avmx 11-11-2004, 10:24 PM Had the same problem. Replaced the blower motor resistor and the problem was fixed. Took about 10 min. Good luck. JazzyMKN 11-17-2004, 10:19 PM Had the same problem. Replaced the blower motor resistor and the problem was fixed. Took about 10 min. Good luck. I also had this problem, but now it doesn't work at all. I'm I looking to replace this resistor also, or will I need to change the blower motor? If so how do I get to it? ...getting cold in Michigan Automotive Network, Inc., Copyright ©2012
