alarm install helpjkBHSO3 11-08-2004, 06:37 PM im trying to install an after market alarm system i need help with the wire colors under the dash for splicing into the following: --- +12V ignition source thats hot when the key is in ON and crank positions but OFF when in the off position --- the wire that goes from ignition to start solenoid --- a wire that connects to all parking lights (blinkers, tail lights, sidemarkers, etc) sierrap615 11-09-2004, 01:21 AM 1. pink at ignition switch pin D, UHJB #2285 pin E1, IPJB #2287 pin D8, and power splice pack power at RUN and CRANK. brown at ignition switch pin B and IPJB #2287 pin C8 power at ACC and RUN 2. yellow before park/neutral safety switch, purple after. auto trans - safety switch on gear selector. manual trans - safety switch on firewall/bulkhead near top of clutch petal shaft 3. brown at UHJB #2289 pin A4, A5, A6, A7(depending on body style), UHJB #2285 pin B4, IPJB #2287 pin E5, E6, F5(brown or org, i would tap here), F7, IPJB #2285 pin A4, A5, A6, headlight switch pin K(brown or org), and at each light i got all this out of a Hanyes repair manual, you can pick one up for less then $20. jkBHSO3 11-09-2004, 06:00 PM thank you sooo much, i have the chilton but it doesnt have color labled schematics ponchonutty 11-09-2004, 08:13 PM can goto www.bulldogsecurity.com for more info on your car too. BluntLostHalo131 11-09-2004, 11:17 PM I have a 96 Saturn SL2.... I am trying to sale it.... Im wanting 4500 for it or best offer.... The only thing wrong with it is the passenger side fender has a crack in it and the dreaded "curse of the saturn transmission breakage"..... I got the transmission fixed now im looking for a buyer.... anyone interested.... Automotive Network, Inc., Copyright ©2012
