Head work?
1more88XJ
11-07-2004, 10:10 PM
I have a 88XJ the # 1 cylinder has bad compression I believe it to be a valve and I would like to know is there any fixes I can do myself. I have found a engine out of a 96XJ classic that I think I can pull the head from. Does anyone know if the head ie.head bolts will match with chrysler to amc block.
rotorfloat
11-07-2004, 10:55 PM
I'm not sure about the head swap, another more knowlegable member may advise there. But are you sure it's a burned out valve? Greater chances are that it's a blown piston (those earlier years tended to detonate occasionally :eek: ).
Unless of course you've determined this already. If you haven't you can find out without ripping it apart (yet).
I'm pretty sure that you'll have to stick to a pre 91 head casting thou...not positive.
