electrical system questions
Howdy, folks. I've been lurking for a few days, and now feel I can ask this group for help/advice; as well as potentially contribute same.
My li'l red ragtop was owned for 24 years by a retired air force transport pilot. He did a great job of keeping the car clean and preserving the appearance, but had some (shall we say) "interesting" concepts about wiring and such. He had the original slant 5 replaced with a 318/904, added front disk brakes, upsized the rear drums, went to 14" large bolt pattern wheels and a dual master cylinder, all good stuff!
I've been systematically finding and returning to "near" stock, such things as burned out dome light circuit, fuse block with extra circuits added to terminals that then overheated and damaged the fuse holders and the box itself, many wire splices that were twisted and taped but not soldered, lots of tape from these splices coming loose, other connectors that have come loose on their mating connectors, etc, etc. (wow, that turned into quite a litany!) Anyway, it's kept me off the street and out of trouble.
I'm a retired electronic technician and radio station engineer, so the wire part is a refreshing challenge, most of the time. I have factory service manuals in paper and on CD, so I generally know what I'm supposed to find, and understand what is supposed to be and why. Having said all that, there are a couple of things that are beyond my experience and understanding.
First, though the car runs pretty well around town, it has a severe hesitation at wide open throttle just before it wants to shift from first to second or second to third. I had thought that was caused by the single exhaust, which seems to be a bit on the light side for a 318 with a 650 Edelbrock carb and (the P.O. says) a cam a little hotter than stock. I recently added a tachometer, and now I'm thinking that the hesitation is the ignition breaking down. The hesitation starts about 3,500 RPM, and the engine will just barely get to 4,000 - 4,200. This is true both under wide open throttle on the freeway, or if I bring the revs up slowly in my parking lot. The car has been converted to Mopar electronic ignition. It has a kinda tired looking "orange box", with the five pin connector. Anyone have opinion or suggestion about ignition, or am I barking up the wrong tree (again)
Second, the P.O. installed the Edelbrock carb with an electric choke wired through a Mopar device which I assume is a choke controller. It's a ceramic rectangle with input and output terminals wired in series with the ignition controlled lead to the electric choke. I found this mounted on a bracket on the topside of the distributor bracket, just below the bottom of the air cleaner. The choke did _eventually_ open fully, but it seemed to me that the temperature sensor ought to be down near the manifold where it would have a bit of heat to sense. It also has a hole in its mounting tab that fits the bolt that secures the coil to the intake manifold, but was kinda crudely mounted atop the coil bracket. I moved it to the intake manifold, and it seems that the choke is opening a bit faster. My question, though, is: do I need this Mopar controller at all, or does the Edelbrock carb have its own controller???
Thanks in advance
Bob
