92 4.0 Very Rough Idle
barker23
11-06-2004, 10:26 PM
Rough idle only while sitting in park. As soon as I give it gas, it levels out real nice. Any ideas????????
Cam7
11-07-2004, 04:52 AM
Check for a Vacum leak. Try cleaning the throttle body and IAC. Does your Check engine light come on?
barker23
11-07-2004, 09:59 AM
No Check Engine light, I cleaned the throttle body and it got alittle better, but not much
scuba4321
11-10-2004, 02:06 PM
clean the IAC inside throttle body, very easly to do
1more88XJ
11-14-2004, 02:53 AM
Barder23, You probably want to check out your m.a.p sensor and t.p.s sensor first, since the both of them can contribute to your rough idling. Just pull off the vacuum from the m.a.p sensor and see if it stays the same or changes. Unhook the t.p.s and see what it does too! and if it hasn't been done in a while, a tune up with spark plugs, wires, rotor and distributor, air filter, oil change, and fuel filter. I just got a XJ and the oil hadn't been changed in a good while, it was idling pretty rough then i changed it, added some lucas oil stabilizer and it made a difference in smoothing that rough idle and gaining its performance/power back.
dima4855
11-15-2004, 03:43 AM
Did this start all of the sudden?
barker23
11-16-2004, 09:32 AM
To: 1more88XJ
I changed all that you said and afterwards it idled very smooth @ 900 rpms. Thanks a million
To: dima4855
I bought the Jeep under this condition and just trying to get it road worthy.
Thanks everyone who relpied for the help.
