Coilovers and Camber Kit on my 98 Civic
98sivicex
11-06-2004, 04:09 PM
I've decided on Skunk2 Coilovers and an Adjustable Camber kit...any comments or suggestions appreciated. [COLOR=blue][FONT=arial black][SIZE=1] :screwy:
Ace$nyper
11-06-2004, 07:39 PM
Get the Skunk2 rates changed I belive its still free also order some shocks at the same time. I would say that it can be a great set up.
Just look into what you want your rates set as. The stock rates kinda stink on the Skunk2s but harder rates will kill your OEM shocks very fast.
Skunk2 makes great parts going with there camber kit wouldn't be a bad idea.
eckoman_pdx
11-10-2004, 04:21 AM
I talked to Skunk2 no more than 5 or so days ago, and was told buy them you couldn't change the spring rates.
Skunk2's 92-00 Civic spring rates are 450 lbs/inch front and 350 lbs/inch rear. If you want stiffer, the 94+ Teg coilovers fit on a 92-95, not sure about a 96-00 (if you caled skunk2 they can tel you). The Teg ones are are 550 front 450 rear (10kg/mm-8kg/mm) 7" springs. Skunk2 uses thier own springs they manufacture. Skunk2 has a 90 day warrenty on there coilovers and no gaurntee to be sag free, though I have never heard of such a problem occuring with their springs. I figured I'd point that out though.
Ground Control DOES do custom spring rates and spring lengths with their coilover sleeves if you want to go that route. They also have a lifetime warrenty to the orignal purchaser and a lifetime gaurntee against sag. Ground Control uses Eibach Race springs. You can get custom rate springs from their site on sale for around $299.00, It's about $338 if you order over the phone. If you want to replace the springs later with stiffer or softer spring rates, different lengths, etc, it's $56 a spring.
Skunk2's number is 909-808-9888
Ground Control's number is 530-677-8600
