Truck problems
soccerdug1
11-06-2004, 03:26 PM
i am having problems with my '93 1/2 ton chevy truck. sometimes the truck will start and sometimes it wont turnover. after is sits for a while it will start and you can drive it but when you shut it off it wont turn over. i have replaced: fuel pump, oxygen sensor, ignition coil, cap and rotor, fuel pump relay and ignition module. and still does not work it any one can help it would be great thanx!!!
gschretter
11-06-2004, 09:05 PM
1. Starter
2. Starter Solenoid - check for wore out starter wire.
3. Battery cables. Both - check for build up.
4. Battery is dying.
Has all the stuff above been replaced? If not then it is time.
I had all kinds of start problems in the past.
What could be happening.
You have more amps in a battery in a cool state. When you drive the truck around the battery loses a little power because of heat. So when you shut the truck off and try to start again the starter is pulling more amps from the battery in which it does not have.. What causes this - Worn Out starter.
If this is happening soon or later your battery will burn up or the solenoid.
Here is the best one:
You turn the key the truck starts but the starter does not turn off until you disconnect the battery. SWEET!
Why: The starter was pulling so many amp that the solenoid was welded closed.
Mikado14
11-06-2004, 10:12 PM
Please correct me if I'm wrong. Did you replace all those parts in trying to find the problem? or, Is this something that coincidentally started happening?
speilman
11-07-2004, 08:39 PM
Not all that mechanically inclinded myself, but I have encountered a similar problem in the past, which turned out being a faulty neutral saftey switch.
soccerdug1
11-09-2004, 07:26 PM
i found the problem it was the battery and cables thanx for all of the help!!!!
gschretter
11-12-2004, 03:05 PM
I told you.
Those battery cables are a pain.
I just had one go back on my winch.
It was sending 12v but 0 AMPS.
