1990 Camry Driver side windowncampb4861 11-06-2004, 02:54 PM Been having intermittent problems lately with the Driver side Power Window. Sometimes the button would work to make it go up and other times it wouldn't. Always went down with no problem. Well now the window went down and it wont come back up. suggestions?? rwood13 11-08-2004, 02:46 PM take the door panel off, use a meter to see if your getting voltage to the motor when you press the switch, if so the motor is bad, if not the switch is bad ncampb4861 11-22-2004, 06:23 PM take the door panel off, use a meter to see if your getting voltage to the motor when you press the switch, if so the motor is bad, if not the switch is bad It's the switch Automotive Network, Inc., Copyright ©2012
