How can I convert to limited slip differential?
joema
11-06-2004, 09:15 AM
How difficult and/or expensive would it be to convert my '04 Silverado's differential to a limited slip or locking differential? What all parts would I need (housing, guts, etc)? Would it be cheaper to get aftermarket stuff, even if I go through gmpartsdirect.com? Would either the transmission or engine management need to be reprogrammed? Before '04, I think they called it limited slip...now they call it 'locking'. Has it really changed? I'm not looking for a performance upgrade...just traction in mud and snow. Thanks.
skipr
11-06-2004, 05:32 PM
I'm assuming it's a 1/2 ton. You need a gov -loc carrier unit, 10 bolt, 30 spline axles. The Ring gear should fit onn the new one. get a GM unit so you don't have to shim it for backlash (should be done anyways). you will need 2 LM501330 carrier side bearings and races made by timken (don't get cheap bearings). And you are looking at 500 for the unit and $60 in bearings, and I hope you have a bearing splitter and press.
silveradoman
11-08-2004, 01:10 AM
Ithink there is a kit in www.stylinconcepts.com, try there...
jbeaulieu51
11-08-2004, 06:01 PM
I wouldnt buy a gov loc if I were u there a plenty of places on the internet that sell limited slip units I would recommend jegs or summitt racing but cheaper units/complete kits can be found brand new on ebay
skipr
11-09-2004, 01:57 AM
Sure you can get a Eaton or a Alburn..etc. I was just trying to keep it simple. Because the Gov-Loc is GM's stock limited slip replacement.
Sivart
11-09-2004, 09:44 AM
If you are not going to be doing any hard core 4wheeling then I would go with the Auburn or some sort of limited slip. I agree with the above. Stay away from the gov lock. Not heavy duty at all.
joema
11-09-2004, 09:48 AM
Thanks!
jbeaulieu51
11-10-2004, 03:39 PM
costs about $150.00 to install in my area
sp3edr4cer
11-12-2004, 08:52 AM
or just get a Z71 and 4 wheel low is all the locking tracktion you need :-D
Rbraczyk
11-12-2004, 08:55 AM
Im surprised that that chevy doesn't come standard with a limited slip.
spackelman
11-13-2004, 04:12 PM
I've been thinking about a powertrax from richmond gear. Seems simple enough to install and the price sounds good.
