Faq Thread
D3rELiC
11-05-2004, 11:20 PM
we are all complaining about how we'd need stickys and stuff
maybe if we start doing an informative thread, we could msg a mod or admin and have it stickied
what do you guys think ?
drftk1d
11-06-2004, 12:15 AM
Its a good idea, and a great start.
drftk1d
11-06-2004, 12:24 AM
Ok, first thing, the forums:
http://www.rx7club.com
http://www.nopistons.com
http://www.clubfc3s.com/iboard/
http://www.teamfc3s.org/forum/index.php?
D3rELiC
11-06-2004, 01:26 AM
how a rotary engine works (http://www.howstuffworks.com/rotary-engine.htm)
looking for something ? click here (http://www.automotiveforums.com/vbulletin/search.php?)
D3rELiC
11-06-2004, 01:32 AM
hahaha, we should link other board's FAQ
Soyo
11-07-2004, 08:46 PM
rebuilds and porting, engine swaps, auto to manual swaps, and any info you need
http://www.rotaryresurrection.com/
drftk1d
11-08-2004, 09:28 PM
damn since nobody will sticky this, we gotta keep bumping it.
we need sticky faqs like yesterday.
it worked for the 240 forum.
fcdriver
11-09-2004, 08:33 AM
Well I second the bump, and we really need some sticky threads on here. Who can we talk to to make this a sticky?
J-Rat
11-12-2004, 03:16 AM
I dont think this area has a mod
fcdriver
11-22-2004, 06:44 PM
Well this bump goes out to all the people wanting to import a RX7 here. I also stole some of the links from a post that FCsilvia made so thank him for showing you where your answers are for importing.
http://www.automotiveforums.com/vbulletin/showthread.php?t=320824
I'll also try to keep this thread somewhere near the top untill we can get it stickied.
ac427cpe
11-23-2004, 03:14 AM
i'll leave this one open, but you guys should post this info in the thread with some rules... use this one if you need to talk/argue about the contents.
sorry it took so long, i've been having computer issues lately.
if you guys want anything else, pm me about it.
D3rELiC
11-23-2004, 09:35 AM
thanks alot, mr2 buddy
D3rELiC
11-25-2004, 07:57 AM
mcs : you cant just say rotary engines got 14 to 20 mpg, an 86 will have a very different fuel consumption than a 94 running 14 pounds...
fcdriver
11-25-2004, 09:44 AM
Very true and I've read where some people have used a standalone and got 25+ mpg on N/A FC's with a few other reliability mods.
D3rELiC
11-25-2004, 12:35 PM
posts in the FAQ thread should be posted here and approved, otherwise we will have a useless FAQ thread
this post should as well be corrected, the specs on the site are for 86-91FC3S 86-89 Specs, and imformation. http://2ndgenrx7.freeservers.com/page1.html
fcdriver
11-27-2004, 07:21 AM
D3rELic is right we should get things approved before we start posting more just to be sure everything is on the line.
With that said I was wondering how everyone felt about adding pettitracing.com and RX7.com to the list for RX7 performance sites?
mcs
11-28-2004, 05:33 PM
sorry i was just doing fuel consumptions on avarage that i mostly hear...
D3rELiC
12-10-2004, 11:42 AM
watcha think of this one ?
WHY NOT USE SYNTETIC OIL ON STOCK ENGINE :
syntetic oil as aditives that arnt designed to burn
rotary engine has a device to lube up the seals, an oil meetering pump (OMP) shoots oil in the rotor chamber, its called an oil meetering pump, unless you have removed that pump (and you are runing premixed oil in your gaztank), running syntetic oil will leave shit in the engine therefore reducing power and life time.
89tracerman
12-10-2004, 11:17 PM
royal purple is a syntetic oil and it works fine on RX7's you should also specify what is a pre mix.
k2dogg86
12-11-2004, 11:50 AM
I just bought an 87 RX7 for $900. Perfect exterior and decent interior. The only major problem with this car is that it has a 3,800 rpm hesitation. Would it be the fuel injectors, spark plugs, exhaust, cold solder points in the cpu? What! Does anyone accually know the answer or have a clue? HELP!
k2dogg86
12-11-2004, 12:06 PM
If you add aftermarket mufflers and an intake to a RX7, wouldnt it run rich? If it runs rich, what kind of hardware would you invest in to control it. If it runs too rich, the apex seals will burn out faster. Right or wrong?
D3rELiC
12-12-2004, 10:46 PM
k2dogg86 (http://www.automotiveforums.com/vbulletin/member.php?u=159502) : no your car will run fine after intake/exhaust mods, T2s and FDs are another story
from the FC FAQ on the rx7club.com :
I have this hesitation whenever I accelerate right around 3500-4000 RPM
The dreaded 3800 RPM hesitation is cause 90% of the time by poor ground connections between the engine, the battery, and the car. Clean or replace all the under hood ground connections. Some people have also claimed replacing/regrounding the pressure sensor's ground wire has helped. If there is still a problem after that, look at cleaning the fuel injectors and (on a N/A) that your 5th/6th ports are operating correctly.
fcdriver
12-26-2004, 03:25 AM
Some intersting facts and specs on third gen RX7 that should be looked to go in the FAQ section, http://www.turborx7.com/rx7specs.htm
89tracerman
12-26-2004, 05:40 PM
sounds good!!!^^^^
drftk1d
12-28-2004, 12:12 PM
Pre-mix: mix motor oil and fuel so that they can be injected into the chambers at combustion time. It is advantageous because the rotary burns a little oil by design. You can remove the OMP to do this, but its not always necessary.
http://www.nopistons.com/forums/index.php?act=ST&f=65&t=14446
89tracerman
12-28-2004, 08:58 PM
post!!! ^^^^^
D3rELiC
02-07-2005, 07:34 PM
posted a link list, if i have missed something, feel free to put the link in here, i'll edit my post :)
