Clutch Problems.....again
Mistaphace
11-05-2004, 08:33 PM
Alright, so I replaced my stock oem cluth with a ACT organic with a lighten flywheel and the master cylinder when my clutch blew the first time. Right now I'm not sure it's blown. I think I may need to replace the slave cylinder. My clutch doesn't bounce up the way it should. The clutch does not go into gear unless the car is off even then when started it pulls a bit as if the hydraulics are screwed up. I'm going to jack it up in the morning and see whats going on, then I'll look into having the slave cylinder installed in the late morning or on monday. Anybody have any ideas as to what the problem could be? Do you think by having to drive with the gears feeling stuck...as if you can't get it out of gear would indicate a problem with the hydraulics? I'm thinking this because of what happens when I start in gear. Any help is always appreciated.
Face
93 Civic Hatchback si
D16 i/h/e
ACT Stage 1 w/lighten flywheel
CivicSpoon
11-05-2004, 08:36 PM
did u bleed the lines completely and check to see if yoy have enough fluid?
Mistaphace
11-06-2004, 09:18 AM
I have not bleeded it this morning, I called my shop and let them know that I would be replacing my slave cylinder.
Mistaphace
11-08-2004, 11:39 AM
Replaced the slave cylinder and that did it.
polacek
11-08-2004, 11:45 AM
Good Job!! :smile:
