88 Cherokee heater fan does not blow.88Jeepster 11-05-2004, 09:51 AM Sometimes it works and sometimes it doesnt. I get hot air but the fan does not go on. Vent, heat or defroster all the same?????????? HELP!!!! Winter is here and I am gonna need to be warm. chico71 11-05-2004, 10:53 AM when you said that some times it works you mean that some times it blows and other times it doesn't blow air chico71 11-05-2004, 10:58 AM if the fan dose not com on you should check the fuse or maybe the switch is bad 88Jeepster 11-09-2004, 11:16 AM Yes, some times it blows and sometiimes it does not blow. The heat works it just does not blow air out. vBulletin®, Copyright ©2010, Jelsoft Enterprises Ltd.
Automotive Network, Inc., Copyright ©2010
