fuel injectors?g_metalowl 11-05-2004, 04:04 AM i would liketo know if any one has changed their injectors on a fist gen, mk1. and if you did where did you get them from cause im kinda drawing a blank here. any input helps, thanks. TRD2000 11-05-2004, 03:11 PM the 4-ag engine was common enough, shouldn't be too hard. have you asked toyota? g_metalowl 11-05-2004, 05:08 PM well...no, not yet because im kinda looking for bigger injectors (about280 to300cc)not stock size because i need to feed more fuel for my turbo setup to hit higher boost TRD2000 11-05-2004, 05:35 PM well toyota supercharged the engine so they would have used bigger injectors for that. I have a feeling they may have turbo'd it in japan as well. plus it got a lot of race use so TRD should have bigger ones... they might be worth checking. if nothing else they might be able to tell you enough to get you sorted. you never know injectors from another engine might fit. 2JZ-G injectors fit a 3S-G perhaps 3S-G injectors will fit a 4A-G g_metalowl 11-05-2004, 05:58 PM thanks for the info trd2000 ill check it out. Automotive Network, Inc., Copyright ©2012
