Problem with Coolant LightMoshimoGTP 11-05-2004, 12:11 AM hI, Yesterday i've changed the coolant bottle with coolant sensor, but the light stills blinking. What can be the problem?... Anyother sensor? Please help! Thanks boschmann 11-07-2004, 04:39 PM On what car? MoshimoGTP 11-08-2004, 11:14 AM 97 Jetta GLX VR6 MoshimoGTP 11-08-2004, 11:20 AM I think is the expansion tank (coolant tank) cap?... can be? boschmann 11-09-2004, 08:23 AM The bottle came with a new sensor, or did you swap the sensor onto the new bottle? MoshimoGTP 11-09-2004, 01:38 PM I changed the bottle with a new sensor.... because the bottle came with a new sensor.... then the coolant light still blinking... i think is the bottle cap... i will change it... any suggestions? boschmann 11-09-2004, 04:18 PM Try overfilling to see if that makes the light go out. It may be a bad sensor. It could also be a wiring problem.... MoshimoGTP 11-09-2004, 06:40 PM I've overfilled and the results was the same... i go to change the coolant tank cap and check the wires. Thanks Automotive Network, Inc., Copyright ©2012
