uncontrolled revvingRGM 11-03-2004, 03:57 PM My son and I just installed a short block in his '88 turbo. The good news is that after a bit of twiddling, it started. The baaad news is that it starts revving uncontrolably. (5k within a few seconds). I suspect the pressure regulator/PR solenoid. Can anybody suggest a check on these components or an alternative fix? FCsilvia 11-03-2004, 04:36 PM My son and I just installed a short block in his '88 turbo. The good news is that after a bit of twiddling, it started. The baaad news is that it starts revving uncontrolably. (5k within a few seconds). I suspect the pressure regulator/PR solenoid. Can anybody suggest a check on these components or an alternative fix? some things i would check. - throttle cable, is it set right? - TPS, often fail, ~$50 new OEM or free from a junkyard - CAS, set right? - coolant seals. remove coolant cap and check for bubbles on cold start. RGM 11-03-2004, 04:55 PM Thanx, FCsilvia- The throttle cable is in its default position and seems to operate smoothly. I assume that the TPS is the throttle position sensor, so that might be a good possibility to check. What is the CAS? RGM MBTN 11-03-2004, 05:41 PM CAS is crank angle sensor. Is the revving steady at 5000rpms? That really just sounds like a stuck throttle. Double check your cable and throttle body. RGM 11-03-2004, 07:44 PM MBTN- Thanks. The revving is not steady at 5k. I suspect it would go to redline if we didn't kill it. When making our first attemp to start it, I had to realign the CAS. Initially, it would not idle, then I rotated the CAS to its clockwise limit. Great-King-Rat 11-03-2004, 08:16 PM If it was TPS or CAS is it possible for it to remain a steady RPM at 5,000? If not then the throttle cable seems a likely cause...but im not sure... RedFC3S 11-03-2004, 09:55 PM +1 for TPS Automotive Network, Inc., Copyright ©2012
