disabling the factory Alarm
95cirrus
11-03-2004, 12:06 PM
I have a 95 Cirrus that had a bad ECM..CODE 71..I installed a used ECM from another 95. The car cranked and ran like new money. on the way home I made a stop at the mall. When I returned, I unlocked the drivers side door with the key.(to my knowleged the central locking system does not work with the key). When I opened the door........Thats when I found out the car had a factory alarm......The horn went off and front headlights flashed!!!! I ended up pulling the fuse for the horn. I cannot get the system to reset. Even with the ecm disconnected the system will not reset. I have disconnected the battery for hours and this will not help.
I was told to insert the key into the drivers side door and lock then unlock the door and this should reset it...That didnt work so I was told to try the passenger side door..This also did not work.
I was told that there is a security module behind the dash that I have not tried.
I wanted to see if anyone else had had a similar problem before tackling this.
I made a call to the local chrysler dealership and was told that the ecm had to match the vin number.....But with the ecm disconnected you get the same result so I was thinking that that had nothing to do with it.
the part number on the original (bad) ECM is 04606064
the part number on the used (newer) ECM is 04606066
The engine will start but shuts off in about 3-5 seconds.
SO, what does this security module look like and can it be bypassed until I order one if thats the problem
thanks,
Kenneth
KENNETH HUBBARD46
11-23-2004, 01:27 PM
thanks,
Kenneth
We have a similar problem with my wife's car.
When we unlock the passenger side door, it disables the alarm.
In the near future we will buy \ install a new alarm system.
When we bought the car, the keyless remote was lost prior to the previous owner trading it in.
ponchonutty
11-23-2004, 08:55 PM
thanks,
Kenneth
You must have a bad switch in the driver's door. I would try to unlock the pass. door to see if it disarms.
95cirrus
11-29-2004, 06:32 PM
I took the door pin switch out and it only has one brown wire. Inside the door frame I was told by the dealer that there is another switch. There is not. The only other electrical connection is for the inertia reel lock on the seatbelt. whick has nothing to do with the alarm system....
The passenger side is the same as well.
The car was not equipped with keyless remote.
I have tried the drivers side and passenger door....Nothing works!!
The car has been at the dealer for two weeks now. They said they have not gotten chance to look at it!!!
ken
ponchonutty
11-29-2004, 09:21 PM
Boy, that sucks!!!
95cirrus
12-28-2004, 03:29 PM
Found out what it was....The PCM and the BCM are shorted....$1,400.00 to repair.......so I'm looking for a wrecked car to get them off.
Kenneth
JenR5
07-13-2005, 08:26 AM
I know it's been a while since everyone has been posting here, but I just started having the same problem. I'm looking for any advice I could get! Thanks!
byron92
02-10-2008, 07:28 PM
same problem here guys my cirrus is stuck in wal mart parking lot, alarm will not go off disconnected battery cable sit for hours tryed keys in locks wont disable. looking for help myself.
shortystired
03-15-2008, 03:43 PM
thanks,
Kenneth
i saw on the internet where a guy had a red random wire he hooked to the psoitive side of a 9 volt battery and the negative side to body ground and it disabled the alarm. mine dont have a random red wire i looked very hard for one. if anyone has an answer on how to bypass this let me know cause i got one that is doing the same thing. i just want to bypass the factory alarm if possible
hs225041
04-14-2008, 10:26 PM
Have a 1999 Cirrus with a similar problem. I have been able to live with the problem, temporarily, by pulling horn fuse and taking out a flasher from the fuse box. Horn does not sound and the lights do not flash. This alarm is a pain suffered by several owners. This is one reason I got the car.
