OBD1&2 issuesCRAZYEG9 11-03-2004, 05:44 AM When I'm ready to put my 96-01 OBD2 B20 in, what engine accesories must be swapped for OBD1, I know the distributer, but I'm not sure about the alternator, fuel injectors, or starter. It's for a 92 Civic. Please help me on this. 96h22ek 11-25-2004, 10:43 AM when you are ready to swap it you will need obd1 injectors, distributor, altenator, and wiring harness but the stock wiring harness out of the civic should work. civickiller 11-25-2004, 01:42 PM wrong 96h22ek, he can use the stock obd2 injectors or even his stock obd1 injectors but since the injectors are already on the obd2 just keep them, he can still use his obd2 dist on obd1. the only thing i dont know about is the alternator because idk if the plugs are different or whatever, and if you will need a harness for plugs. 96h22ek 11-25-2004, 09:10 PM I am not wrong because i have done 3 of these swaps and that is the easiest way if you try to use the injectors and distributor you have to cut and rewire the plugs civickiller 11-28-2004, 04:53 PM ok so you go and waste money on obd1 injectors, obd 1 dist, and obd1 alt just to save yourself time from switching plugs. oh yeah genius at work here. splicing in plugs is easier then swap injectors, dist etc. i wouldnt trust you doin my swap Automotive Network, Inc., Copyright ©2012
