Transmission Problemgreatbarralbion 11-02-2004, 07:34 PM I Have A 96 Dodge Ram 2500 318 The Transmismision Ocassionaly Has A Hard Time Getting Out Of 2nd Gear If I Let Off The Gas And Accelerate It Changes Up. The Problem Seems To Be Getting Worse Could This Be A Computer Problem? rwood13 11-04-2004, 12:15 PM most likely a soliniod inside the trans is hanging up, a trans flush may help, may not, any tranmission people out there ?? oopsth 11-17-2005, 01:54 AM I Have A 96 Dodge Ram 2500 318 The Transmismision Ocassionaly Has A Hard Time Getting Out Of 2nd Gear If I Let Off The Gas And Accelerate It Changes Up. The Problem Seems To Be Getting Worse Could This Be A Computer Problem? was there a resolution to the syptoms? I am having the same issue on my 89 B250 after the engine is warm... theFREAKnasty82 11-17-2005, 02:57 PM was there a resolution to the syptoms? I am having the same issue on my 89 B250 after the engine is warm... Go to a tranny shop and have them check your governor pressures. You could have a worn throttle valve, but nonetheless, get those pressures checked out to see what could be hangup. Check around the carbuerator, there should be a linkage that goes directly to the transmission. Make sure it moves freely and check underneath by the transmission. If all checks out, you can actually adjust the position of the linkage by loosening the locknut and moving the rod toward the back of the van, that should help tighten things up, though your upshifts might be a bit rough. You might need to play around with it until you find a set up that appeals to you. Automotive Network, Inc., Copyright ©2012
