Pulling wires from engine compartment to the inside of the car/under the steer wheel?
DeMiNe0
11-02-2004, 07:20 PM
Hey guys. I'm planning to install an air horn in my blazer. I have everything installed and working like a charm. The only thing i need to know how to do is, run the horn switch from the engine compartment to the inside of the truck.. Maybe under the steering wheel. How would i go about doing that? Right now i have the switch and its extra 15 feet of cord tied up with a tie rap in my engine compartment :P, i would love to run that under the steering wheel then just mount it under the dashboard, or even better if i can run the wire somehow up into the ceiling of the car then pop the switch on the wire, this way i can mount the switch on the ceiling insted.
DeMiNe0
11-03-2004, 02:29 PM
bump
someguy000001
11-03-2004, 06:41 PM
Well, you could shove the wire through an existing grommet or drill a new hole. I would drill up under where the pedals are, making damn sure there was nothing important on the other side.
wolfox
11-04-2004, 10:11 AM
Ditto here. I would also spend the extra bux to pick up a box of wire loom too. It will protect the wires in the engine comparment and through the cut you make through the firewall. A small goop of silicone where you made the cut will keep moisture and bugs out.
