K&N install. Shocking results.
miket
06-08-2001, 02:00 AM
Can't take the chaff on XOC anymore. Nice to find another site.
Anyway, I popped the K&N filter (33-2031-2) into my V6 M/T. It seemed well seated and sealed. The increase in throttle response and increase in power, especially below 2000 RPM, was WAY more than I expected. The engine sounds a lot different too. Jokingly to myself I thought, I wonder if it's that responsive cause the filter isn'tsealed and air's getting sucked around the filter.
When engine braking down a steep hill at 3000-3200 RPM it's way whinier than before. It's less throaty sounding and more breathy sounding. So, I thought I heard a hiss. Low and behold, popping the lid at home, there's a hiss from somewhere around the cylinder that's closest to the passenger seat. I dunno if it's normal, maybe it's something spinning I hear, but it sure sounds like a vacuum leak.
WTF?
mikeT
Philosopher
06-08-2001, 01:47 PM
"Chaff" That's a good one. Quite appropriate. :)
Yikes, can't help you with that one, sorry. I have a couple odd noises that come and go in my dashboard and from under the hood but nothing that has me really concerned yet.
miket
06-11-2001, 12:43 PM
Well, the dealer agrees it sounds like a vacuum leak. I'm not sure whether the
noise was there before I popped in the K&N. I'll probably swap back to the paper
just so they have nothing to whine about when I get it serviced tommorow.
It would be strange for the filter to pop off a hose on the other side of the engine.
mikeT
miket
06-19-2001, 05:35 PM
Well, no leak.
The K&N makes a nice improvement in the throttle response and boosts power just a bit. It's boosted just enough to not have to downshift going uphill when you'd normally expect to.
As for installation: the directions I got were for a Pathfinder. The filter fits anyway. Ignore the part about pulling out the tray. When you're placing the cover back on the box, you just gotta wiggle it around a bit so the edges of the cover and are flush with the bottom of the box.
mikeT
Pritch28
12-23-2003, 02:33 PM
Well, no leak.
mikeT
hey mike. i installed a pop charger on my supercharged X, and ever since then, i have had a loud whistling sound that only happens at a particular rpm range, usually 2500-3000rpm. when i increase/decrease throttle at this range, the sound fluctuates on/off, so i'd bet money that its a vacuum leak someplace. did the dealer help you out on where to look for the possible leak that you had? the noise i hear is coming from the driver's side. thanks. :banghead:
OffroadX
12-23-2003, 04:03 PM
Do you realize your post is 2.5 years after the last one in this thread?
Pritch28
12-29-2003, 02:03 PM
Haha...no, i didn't notice the date on his post. Guess i won't be hearing from him. :rofl:
