no heatChuckccr 10-31-2004, 08:37 PM I have no heat! I wonder if it might be the heater core? Someone told me to check the heater control valve? Where might that be found? I'm getting cold so I need some help! beyondloadedSE 11-01-2004, 07:12 AM Whats your coolant level in your resevoir? Is the car overheating? sbest737 11-06-2004, 08:26 PM I have no heat! I wonder if it might be the heater core? Someone told me to check the heater control valve? Where might that be found? I'm getting cold so I need some help! My car also runs pretty cool, but I think it has to do with one of the codes that I had show up today?? Guess this is a common problem with contours! Chuckccr 11-07-2004, 09:45 PM car temp. is normal. heater core cover is warm,but no hot air. coolant level is good. core not leaking. what else could it be? beyondloadedSE 11-08-2004, 06:57 AM If you have the duratec V6, the waterpump is pretty known for failure since the plastic impellar shatters over time. lildeegurrl0911 11-16-2004, 09:31 PM I had a problem with my heat when I first got my car. I am not sure what year Contour you have but on the 98's there is a recall on part of the heater. Call Ford and have them run a VIN check on your car and they will let you know if you have the problem or not. I took mine into a Ford dealership and the fixed it for free. Automotive Network, Inc., Copyright ©2012
