OverDrive Lightjsa 10-31-2004, 02:35 PM I drive a 95 Explorer with about 150,000 miles on it. Recently the "OverDrive Off" dummy light has been blinking whenever the car is on Furthermore the car seems to be driving as if the OD is indeed off Toggling the button on and off makes no difference. If anyone has any idea I would appreciate hearing it. Thanks dxrflyboy 11-06-2004, 06:36 PM Without a hands-on diagnosis, I can only say the trans. is malfunctioning. It could be an electrical, hydraulic, or mechanical problem. wgretzky099 01-03-2006, 06:22 PM I know basically nothing about cars but I had the same problem with my 95' explorer. I disconnected the battery for a few minutes for a few minutes and that solved the problem for a while. However the flashing o/d light came back. Then I replaced the throttle position sensor and reset the battery again and its been a couple months and been fine. bsnyder55 04-12-2006, 09:24 PM Check threads in this forum. There is someone with the same problem Automotive Network, Inc., Copyright ©2012
