no bus message 2001 stratus
hbeardy
10-31-2004, 12:50 PM
my 2001 dodge stratus started to just die on me. and won't restart for like 20 minutes. will not even turn over and a message comes on that says no buS. Any help with this problem wound be great.
intrigue2001
11-04-2004, 08:24 AM
Go to dealer and they will reboot both the computers. no bus means it lost comunication with both the computers.
hundahunta
11-09-2004, 02:55 AM
possible pcm...
hundahunta
11-10-2004, 11:08 PM
This is for a 98 stratus but it is a start~
NO: 08-31-97
SUBJECT: "No Bus" Message In Instrument Cluster V.F. Display
DATE: Sept. 12, 1997
SYMPTOM/CONDITION:
"No Bus" message in instrument cluster vacuum fluorescent display.
DIAGNOSIS:
Connect Scan Tool (DRB III). If DRB III indicates "No Bus" at cluster but can communicate with other modules, remove cluster and look for a hair-line metal sliver between terminal #4 and #5 of the blue wiring connector, refer to illustration. If a sliver is present perform the Repair Procedure. REPAIR PROCEDURE:
This bulletin involves removing a hair-line metal sliver shorting the blue instrument cluster terminals.
Break and remove a hair-line metal sliver shorting the terminals in the blue instrument cluster connector. See Figure 1.
Install instrument cluster, verify "No Bus" Message is gone.
