Alarm Problem
racer_65
10-31-2004, 02:05 AM
I own a 2000 Nissan Quest minivan. Recently, I had this problem where the alarm cannot be shut off by unlocking the vehicle with a key. According to the owner's manual, there are 2 ways to turn off the alarm. One way is to unlock the vehcile with a key; the second way is to unlock the vehicle with the remote keyfob. My remote is no longer working, so I cannot use the second method.
Now I can no longer use the vehicle. The alarm sounds whenever I enter the vehicle, and it deactivates the ignition so I can't start it. Therefore, I was forced to take it in to the dealer. The dealer diagnosed the problem to be something wrong with the vehicle entry module, which is an electronic unit. They want to charge to a whopping $800 for this job, including diagnosis, parts, and labor to replace the module.
Can anyone offer some advice? Is the dealer taking advantage of me since the car is not driveable (it was towed in)? How much should this job cost? Is this the kind of thing other independent shops can fix? Can I fix it myself? Thanks in advance.
ponchonutty
11-01-2004, 07:53 AM
are u sure it's an OEM alarm?
racer_65
11-01-2004, 04:00 PM
Yes. It's an integrated system. The electrical diagram is even shown in the Haynes manual. The actual name of the module is called "Smart Entry Controller" (except it's not acting very smart in this case).
ponchonutty
11-01-2004, 08:36 PM
have you tried unlocking it with the key in the pass. door or rear door if you have a lock there?
racer_65
11-02-2004, 04:52 PM
Yup, tried all those. The alarm still would not shut off.
However, before I damaged the remote keyfob, it would shut off when I hit the "unlock" on the keyfob.
ponchonutty
11-05-2004, 07:44 PM
My guess is the "switches" in the doors no longer work since they've never had to before. You'll have to take it to either the dealer or alarm shop for help.
Louie B
11-08-2004, 06:09 PM
I have a 1999 Nissan Quest with an OEM factory alarm that will not arm itself. The remote will only open the door, and the LED blinks only when the door is open. When I try to use the key to arm it, it still does not work.
