dead battery (how the heck do you replace)
mcgunny
10-30-2004, 08:44 PM
I cant even find the battery, this is the most ignorant thing I have ever saw. I will not pay someone to replace a dang battery. Any one know the easiest way to replace the battery.
Also any battery spec's? I dont have the owners manual.
I got a great deal on the car (600) just turned 100,000 but i'm already having to dump money in this thing!!
eXcelon
10-30-2004, 10:04 PM
turn the wheel to the left. then look in the drivers side wheel well you will see a cover with the battery picture, take the panel off there are 4 or 5 clips i believe. then theres the battery.
scotts96neon
11-06-2004, 11:23 PM
battery is probably under the back seat or in the trunk if it is not under the hood. a good battery will read 12.6 volts on an volt meter. 12.4=75%, 12.2=50%, 12.6% being 100% charge.
rwood13
11-08-2004, 12:09 PM
I have a 97 Stratus, as eXcelon says the batt is in front of the drivers tire behind a panel, I have had good luck with Wal-Mart batts, just go by their guide, rule of thumb double the cubic inch of the motor and that is the minuim cranking amps, ie 300ci should have a 600 cold crank amp battery
