Wire routing
rrdstarr
02-20-2002, 08:18 PM
I don't know if this is an original usee for this tool, but I'd thought I'd share it anyway! I hate using a coat hanger to pull wires through the firewall so tonight I used my flexible pick up tool, with the spring steel claws. I just punched a little hole in the grommet, expand the spring jaws. Let them collapse and pull the wire right through. I think this a better tool because it doesn't collapse like a coat hanger, its more rigid!http://files.automotiveforums.com/uploads/779095Flexibletool.jpg
rrdstarr
02-20-2002, 08:20 PM
http://files.automotiveforums.com/uploads/294183Flexibletool2.jpg
ChuckH
02-20-2002, 08:46 PM
Uh, what are we wiring? :D
rrdstarr
02-20-2002, 08:49 PM
Radio Shack In/Out thermometer! Just had to pull the probe through the firewall.
ChuckH
02-20-2002, 08:51 PM
I was just going to post that I figured it out after looking more closely to the end of the wire. BTW, I'm at work and just leaving. TTYL!
Snoopy
02-21-2002, 01:39 AM
I've used a wire feeder but that seems like a better idea. Thanks for the info.
imcougar
02-21-2002, 02:15 PM
I have been using the fish wire:)
Xlax
02-21-2002, 05:48 PM
Rick,
do you use that thing for other things besides pulling wires?.
In/Out thermometer !!!. I did not know you are now living in your truck.
:flipa:
brad77
02-22-2002, 02:16 AM
dammit...had to post this twice. here goes:
It's hard to tell from the pictures, but isn't the outside temperature sensor mounted in the engine "bay?" Wouldn't engine heat affect the readings? I heard somewhere (don't ask where) that most car thermo sensors are mounted near the ground to avoid heat sources.
rrdstarr
02-22-2002, 09:15 AM
No the sensor is out under the ARB away fron engine heat. The sensor has 10' feet of cord so you can put it wherever.
brad77
02-22-2002, 12:20 PM
Gotcha...very cool. I knew I was missing something.
