Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > Suburban
Old 10-26-2004, 10:00 PM   #1
franklinj
franklinj Normal reputation
tbi engine oscillating idle, when cold
1989 sub, idle up and down at a cold start, seems to disappear when warmed. also, after shutdown at operating temp. , come out to start within 15 minutes and it doesnt want to operate at all till "warmed" up. replaced all sensors,iac,temp,egr,map,pcv,fuel regulator, nothin doin. any assitance?
franklinj is offline   Reply With Quote
Old 10-28-2004, 11:37 PM   #2
4onFloor
4onFloor's Avatar
4onFloor Normal reputation
have your fuel pressure check while the engine is cold, if you haven't already
4onFloor is offline   Reply With Quote
Old 10-29-2004, 08:56 PM   #3
Fireplug
Fireplug Normal reputation
Re: tbi engine oscillating idle, when cold
Clean out your IAC valve on the TBI and clean the TBI unit inside and out
Check you ign coil for any crud built up on the post
Fireplug is offline   Reply With Quote
Old 10-30-2004, 02:27 PM   #4
Dr. Eagle
Dr. Eagle Normal reputation
I think you are on the right track with that reply. Look for a fuel problem, clogged filter or weak fuel pump. Low fuel pressure when cold will manifest itself just that way since the engine is run richer by the computer when cold...
Dr. Eagle is offline   Reply With Quote
Bookmarks
Google
Web AF
