Re: 1999 Pontiace GA Shakes In Idle
Like I said it only happens when sitting idle in drive. Neutral and Park it gets a little better about 75% better and when you turn on the A/C in drive (sitting there) it get's even worse but like I said, it doesn't shut off. As soon as you start moving they shaking goes away even 1 mph. It couldn't be the tires because I'm stopped when it happens. And the dealer and various mechanics I've had it at hooked it up to all their computers and found no codes. No they did not do anything about the motor mounts because I opted not to replace them because 1) they weren't broken and 2) they couldn't guarantee me that would solve the problem. We're stumped but I would like to get it fixed. The transmission mounts are fine too according to the mechanics. Now, if it was the motor mounts (they're not broken by the way) could it be the rubber in them expanding as the one dealer told me that's causing it to vibrate and shake? or could it be possible a plugged fuel injector? But that would throw codes.
Thanks for your reply to this.
