Engine Light ON
rash_vyas
10-26-2004, 11:17 AM
Hi, .
I am having problem in my 1999 Honda Civic LX 4 dr Sadan Car
I lost my Gas Tank Cap, I was driving my car without Gas tank cap 1 day but no indication. I got one cap which is not honda Civic cap, but it fitted perfectly. Now after 5 days it started giving me Engine check light after starting car. This light comes any time after driving .5miles to 1 mile.....from last 2 days I am driving my car with proper Honda Gas Cap...but still problem exist.
I could be gas cap or some other problem...I went 2 mechanic they said they are not able to read my computer for this problem...
Pls help.
THanx & Regards,
Rashmikant Vyas
GScivic7
10-26-2004, 12:13 PM
it's probably the gas cap. If there isn't a vaccuum in the gas tank it will trip your CEL. Next time you go fill up your tank listen for that whoosh sound.
Beastiek2
10-26-2004, 01:20 PM
If ya got the proper cap then your all good diso the battery to get rid of the engine light. See if it comes back, it shouldnt if you fixed the problem.
Killa_CRX
10-26-2004, 01:43 PM
Don't have to disconnect the batter... just pull the hazard light fuse out for 10 seconds... this resets the ECU, and still leaves power to the radio (in most cases) so you don't have to reprogram your stations afterwards :lol2:
rash_vyas
10-26-2004, 05:13 PM
[QUOTE=Killa_CRX]Don't have to disconnect the batter... just pull the hazard light fuse out for 10 seconds... this resets the ECU, and still leaves power to the radio (in most cases) so you don't have to reprogram your stations afterwards :lol2:[/QUOTE
Hi,
I appriciate your reply, It will be great help if you can tell where I can find this Fuse..As I checked both one near Battery and one below stering....where exactly find this fuse.
Also this I have to remove when the car is On or off.
Thanx
Rashmikant
Civic_D16Y5
10-26-2004, 05:18 PM
i know for a fact that under the hood there is a efm fuse, pull that out for a little while, but if the hazards work too thats cool
Killa_CRX
10-26-2004, 05:27 PM
Yep... fuse box under the hood... right side, between the strut tower, and the fire wall.... the fuse diagram should show you exactly which fuse it is.
ridestreet84
10-26-2004, 05:46 PM
please do this with the car off or you might smell like bacon afterwards all electrical work should be done with the car off and preferbly the battery disconnected but if your worried about having to reset your radio stations make sure the car is off
rash_vyas
10-26-2004, 05:52 PM
Hi,
I checked there is no efm fuse under the hood......any Idea..how much Amp fuse..is this?
thanx
Rashmikant
Beastiek2
10-26-2004, 05:59 PM
Disco battery reprogram ur 6 stations =)
ridestreet84
10-26-2004, 06:02 PM
i agree with you man
Killa_CRX
10-26-2004, 06:30 PM
Haha... some of us have more than 6 presets... and custom eq's :iceslolan
And some of us also own a helms manual :rolleyes:
Beastiek2
10-26-2004, 06:40 PM
When this guy bitches about his EQ I'll worry about it then. Helms is the best yes.
Schister66
10-26-2004, 09:05 PM
Disconnect the battery and then wait 30 secs, that resets code in most cars for idle and other small code problems. The gas cap was probably not sealing correctly and the fuel pump probably caught some air or something idk. Try the battry idea, if that doesn't work post again.
rash_vyas
10-26-2004, 09:30 PM
Hi,
I removed the said fuse and put it back after 30 seconds...but still problem exists...dico battery will help ?
rash_vyas
10-26-2004, 09:33 PM
Hi ,
I removed this fuse and put it back after 30 seconds..but still no help...
Could you suggest me more..
Thanx
Rash
rash_vyas
10-26-2004, 09:34 PM
Hi,
I tried removing the fuse still no help...
racingnut10
10-27-2004, 12:53 AM
Disconnecting the battery will clear it as well as disconnecting the BACK UP fuse from the fuse/relay box on the right side of the engine compartment this will also clear you radio, so be prepared if you have anti-theft systems
MY RECOMMENDATION. Dont clear it immediately! Go ahead and check out what fault code registered so that you know what happened. To do so turn the key to ON, but dont start it. Remove the passenger side kick panel and find the double female connector sitting in the blue protective rubber covering. Use a wire to jump the two sides of the connector and look at the check engine light as it begins to flash. Tell me what the flashes were, and I'll give you the corresponding trouble code.
Killa_CRX
10-27-2004, 08:49 AM
as far as I'm aware, OBD2 ECU's don't flash codes... they have a diagnostic port for an OBD2 scanner, not a jumper plug.
If he does want to get the code scanned... some place like autozone does OBD2 scanning for free.
racingnut10
10-27-2004, 02:09 PM
I'm ont totally sure either, however I have a 2000 HX (OBDII) that I used this techinque on to find out my cyp sensor in the distributor was bad. I believe the car uses both methods, with the obd2 diagnostic port being on the other (drivers) side near the fuses.
But yes, you are definitely right about autozone doing obd2 scans for free.
rash_vyas
10-31-2004, 09:02 PM
HI,
I found the problem, My oxygen sensor was bad..today I replaced that and my check engine light is gone..
Thanx to all for replying so fast..without all your help it was not possible....
Thanx
Rash
gunnmen01
11-01-2004, 10:31 PM
try an auto parts store, they can read and clear codes also. if you clear the code and it comes back on there is a problem........ a loose/missing gas cap will set a p1456 code-meaning the comp thinks you have a fuel leak.... try autozone or oriellys or pep boys
gunnmen01
alfonso2501
08-31-2006, 08:41 PM
What’s up everyone! I hope the mods don’t get too upset about me digging up a real old thread but it helped me out & I wanted to share my experience.
I got a CEL the other day, went to autozone & they printed out 2 codes for me:
TROUBLESHOOTING P1456
Evap “Emission Control Sys” Leak Detected
(gross Leak/No Flow)
Fuel Tank Temperature Sensor Circuit malfunction
After doing a search I did what Beastiek2 & ridestreet84 recommended & disconnected the battery. No problem ever since. Thanks.:thumbsup:
