Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Astro > M Bodies
Old 10-26-2004, 12:26 AM   #1
sniper4x4
sniper4x4 Normal reputation
Send a message via Yahoo to sniper4x4
whats necessary to fix my tilt column ?
The tilt column on my 90 Astro wobbles is it a easy fix ? it sems to be doing it from the tilt joint.
thanks in advance
Toys:
04' Infiniti G35 sedan
99' GMC Suburban 10" lift
99' Civic
08 High Jumper Sandrail
My favorite Toy 73 Kona 463 Olds
sniper4x4 is offline   Reply With Quote
Old 10-29-2004, 08:57 PM   #2
michael53m
michael53m Normal reputation
I had the same problem with my 88 Astro. I couldn't find any info on how to fix it or figure it out myself. So I went to the junk yard and got a non-tilt steering column and installed it. It works fine, of course I got the steering column from another 88 Astro at the junk yard. Only cost me $35 and an hours worth of work.
michael53m is offline   Reply With Quote
Old 10-30-2004, 02:42 AM   #3
sniper4x4
Re: whats necessary to fix my tilt column ?
Thats that idea actually crossed my mind to pick up anoth tilting unit from the junkyard since my cruise control buttons are flakey as well.
Toys:
99' Civic
Old 12-07-2004, 06:08 AM   #4
holymix
holymix Normal reputation
its not an easy job. but you will need steering wheel puller. if it has air bag you might not want to do it the clock spring has to be int he right place.but if its not air bag i will be able to walk you though it i dont want air bag to deploy on you if it has air bag its a little more tricky.Let me know if i can figure out how i got here.God bless.
holymix is offline   Reply With Quote
Old 03-03-2005, 02:20 PM   #5
grampatom
grampatom Normal reputation
thanks in advance
I have this same problem, would like to swap steering columns, but can't readily see how to remove the column from the vehicle. Have disconnected switches, removed nuts that hold the column collar onto the bottom of the dash, but it still isn't loose. Do you remember the steps to removing this thing? Would appreciate any info you can provide. Thanks. Grampatom
grampatom is offline   Reply With Quote
Bookmarks
Google
Web AF
