1992 lumina wont shift could it be the VSS
Big Ape
10-25-2004, 11:02 AM
Goes into reverse fine and it goes into low gear if you stomp on it it will shift into second but thats its could it be the VSS or is the vacume mod
jeffcoslacker
10-25-2004, 11:20 AM
I'd bet on a modulator or the hose to it is cracked or collapsed.
richtazz
10-25-2004, 03:16 PM
I agree with Jeff, sounds like a vacuum modulator problem. Try shifting manually, if it shifts then, it's definitely a modulator. IF it won't shift manually , you may have a valve body problem.
