hydrolock?RiceRocket18 10-24-2004, 02:58 AM what would be the signs of hydrolock? i cleaned the throttle body yesterday. and not sure if any of that carb cleaner got into the cylinder. kjewer1 10-24-2004, 03:04 AM You would need a lot of carb cleaner to get in there to lock up the motor. And that stuff evaporates fast. Why, what did you break now :D RiceRocket18 10-24-2004, 11:54 AM LOL... it's just that i decided to clean the throttle body. i already had some serious misfiring problems at low rpms... and now after cleaning... the problem seems to be getting worse. i already changed wires, regapped the 7es and then changed back to the stock NGK (helped a lot). and now after cleaning.. it seems everytime i let off gas at 2000 or below the RPM drops! dramatically and then comes back up. JoeWagon 10-24-2004, 02:28 PM I don't know if you've been following one of the other threads going on about BOV recirculating, but as a longshot, are you? RiceRocket18 10-24-2004, 02:41 PM :iceslolan yes but JOE!!.. i never had those kind of problems before. i mean never!!... i've been venting for a year and those problems are recent. kjewer1 10-26-2004, 04:03 AM You didnt get any cleaner in those holes int he bottom of the TB did you? The wax used in the Fast Idle Air Valve can be damaged by solvents. Which would probably make it always open. Not sure if that will cause what you describe, but its worht mentioning. GSTRacerNVUS 10-26-2004, 09:25 AM I've had that happen before when I was replacing the Tps sensor and it wasn't adjusted properly. So, when I hit the gas it about gave me whiplash, and when I let off it felt like I was crawling. EVOclipse 10-26-2004, 09:25 AM just an add on question, but could someone explain hydrolock a little to me...i thought its what happens when you get water in your cylinders...but i just read an article on water injection. and how you can boost like 29 psi on it(modified mag) GSTRacerNVUS 10-26-2004, 10:31 AM ON hydrolock: Here's one with pics + some other info. http://www.v6performance.net/forums/showthread.php?t=35187&page=1 Ok.. I found these, but it didn't really do that good of a job explaining it. http://www.audifans.com/archives/1996/04/msg01313.html http://forums.audiworld.com/a4/msgs/2103325.phtm On the water injection system: http://www.aquamist.co.uk/ (Check out the design concept page) JoeWagon 10-26-2004, 01:55 PM I think the main thing is that water cannot be compressed at all. So if you get into a lake, get scared and hit the gas to get out... there's plenty of vacuum by the engine to fill the cylinders with enough water where they cannot compress fully. It stops rotating because it won't get to TDC to go around, and the impact either stops the motor for a rebuild, or breaks a bunch of crap. :) yoshimitsuspeed 11-02-2004, 11:57 AM I would also do a boost leak test to make sure every thing is sealed up properly. Automotive Network, Inc., Copyright ©2012
