tranny fluid where do u fill at and how much
Redline_civic91
10-23-2004, 11:48 AM
hey where do u put the tranny fluid in through its an 95 automatic accord and how much quarts do i need? my car feels like it shifts gears too hard so ima try changing the fluids
BullShifter
10-24-2004, 12:59 PM
Those generation accords have a hard shift as a natural condition. I had a 97 ex that would chirp the tires 1-2 shift at redline.
Front of trans top side is the dipstick. Look down between the radiator and front of trans, you should see a small yellow ring - that's the stick & fill hole. Check trans level with engine off.
scubawrstlr
10-24-2004, 09:31 PM
how do you drain the trans fluid on a 90 ex?
Redline_civic91
10-24-2004, 11:00 PM
so the dip stick is on the top side in front of the tranny ok. The stick and fill hole is that where i put the fluid through?
BullShifter
10-25-2004, 01:25 AM
On the passenger side(right side bottom) It's the only bolt with a square opening on the side - use a 3/8" ratchet to remove plug
Yes, after filling start car and run through the gears. Reverse for 5 seconds, neutral for 4, drive for 5, put it back in park, shutoff engine, check level. It's always easier to start low and add fluid than it is to drain an over filled trans.
97accord-ex-v6
10-25-2004, 07:04 PM
I just poured mine down the dipstick tube, I put some fuel tube over it and used a funnel. That was before I knew it had a fill hole. lol I think it took like 3 qts. But that is for a 97 v6
