Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > RAV4
Old 10-22-2004, 06:33 PM   #1
x703jko
x703jko Normal reputation
Unhappy Stuck Throttle
I have a 1998 RAV4 (4WD, 4 Door). Yesterday while driving at highway speeds the engine began exhibiting what appears to be a stuck throttle if I rev beyond 3000 RPM.
I don't think the throttle butterfly or the cable is actually sticking because the butterfly appears to return to the idle position when I release the gas pedal.
Hence, I suspect a vacuum leak or something similar.
I'm going to read codes out this weekend.
In the meantime, can anyone advice me on what they think the problem may be?
Thanks
Jeff
x703jko is offline   Reply With Quote
Old 10-23-2004, 12:05 AM   #2
choppermike
choppermike Normal reputation
On my Rav 4 the throttle stick at idle if I don't keep the throttle body clean. About every 5000 miles I take off the intake boot and take a rag with a little carb cleaner on it and clean all around the butterfly valve with the valve open. Reach way in there and clean out all that crud, works fine then..
choppermike is offline   Reply With Quote
Old 04-05-2005, 11:52 AM   #3
Badboyzz
Badboyzz Normal reputation
Unhappy
Having a problem with the idle going up too. It tripped a code in the ECU. How do i get the codes from there??? Can i jumper something or is there a way to find out the codes without going to a dealer????
Badboyzz is offline   Reply With Quote
Bookmarks
Google
Web AF
