trouble woth OBC
wickedmind2000
10-21-2004, 05:18 PM
on my 1988 735i the OBC turns on sometimes and most of the time its off,then i have to put in the time and date again,again ,and again if any1 can help me just email or pm me @ anytime thanx, 7`s Kick ASS
jeffreyb4me
10-21-2004, 06:58 PM
Does the radio also loose memory ? ? Any other info? ? ?
wickedmind2000
10-21-2004, 07:17 PM
nope,nothing else loses memory only the OBC
jeffreyb4me
10-21-2004, 07:28 PM
whooo, that was quick, I wnt to check something, post you back Fri, if you can wait. Perhaps someone else has a good answer 'til then.
wickedmind2000
10-21-2004, 07:34 PM
u think i sould replace it?
jeffreyb4me
10-21-2004, 07:36 PM
No, no, no.....I think you should wait 'til tomorrow for me to reply to your post with a better 'informed' response....................jeff b.
wickedmind2000
10-21-2004, 07:38 PM
ok,thanx,there`s a guy from the neiborhood said he got 1 for 80 bucks?>
jeffreyb4me
10-23-2004, 10:13 AM
wickedmind2000 [].....if fuse F20 is okay [ you've actually replaced it] and still have the problem and the OBC is securely locked into it's plug by the control console lock, the problem must indeed be the OBC itself though,for this symptom, it'd be unusual. F20 is also "key off" B+ for several other consumers, not just memory power supply. Hope this helped.
jeffreyb4me
10-23-2004, 10:16 AM
One more note, as you can see from "KC Ron Carter"'s post for your radio, F20 does not power radio memory on E32's as it does on other models. The radio uses F21.
