Replacing Valve Cover Gasket.
henrymv
10-21-2004, 12:00 AM
I am gonna replace the valve cover gasket on a 90 Accord EX....car has 190K miles....it looks like oil is just beginning to seep out and one spark is starting to show a touch of oil. Question....any tricks I should know? Are the spark plug gaskets easy to replace?? What else should be replaced? YOur help and input is appreciated...
mpumas
10-21-2004, 02:22 AM
Adjust the valves while you are at it. Put silcone sealant at the sharp corners where the gasket goes up over the camshaft.
henrymv
10-21-2004, 02:56 AM
Ok....I have never installed any gaskets made of rubber....what type of sealant do i use on the rest of the gasket??
What tools do I use to adjust the valves???
mpumas
10-21-2004, 03:01 AM
You do not need any other sealant. You need a feeler gauge, screwdriver and a 10 mm???? end wrench and a Haynes or Chilton manual.
henrymv
10-21-2004, 03:03 AM
NO sealant.....wow, i am so used to those yucky cork gaskets....I got everything except the feeler gauge...another trip to the parts store!! LOL
Thanks for your input
JimmyzGarage
10-21-2004, 10:31 AM
Make sure you get the kit from Honda. It has the gaskets for the spark plug holes too. The Honda parts dept. recommended to not use sealant when installing.
henrymv
10-21-2004, 10:39 AM
I called O'reillys Auto parts and they have the whole kit with 4 washers, 4 spark plug gaskets and 1 valve cover gasket
Honda wants $59 for the kit but O'Reillys wants $22...think there is adifference in quality?
