Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Camaro > F-Bodies (Camaro and Firebird) > Camaro Discussions
Old 10-20-2004, 08:28 PM   #1
Cbballplaya
Cbballplaya Normal reputation
more power for 89 camaro
what is the best way to get a little more power without making a huge change(nitrous turbo etc.) i found a chip that claims it will provide 20 mor horse and 36lbs of torque and dissable the governor. I was wondering if any of you guys know any other tricks on how to get more power.
Cbballplaya is offline   Reply With Quote
Old 10-20-2004, 09:15 PM   #2
Dober89
Dober89 Normal reputation
Re: more power for 89 camaro
For starters, what kind of engine do you have in the car right now??
Dober89 is offline   Reply With Quote
Old 10-20-2004, 11:16 PM   #3
drvngstorm05
drvngstorm05's Avatar
drvngstorm05 Normal reputation
ok do u have a sixer? 305 tbi? 305 tpi, or 350tpi?
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
drvngstorm05 is offline   Reply With Quote
Old 10-20-2004, 11:42 PM   #4
Genopsyde
The President
Genopsyde's Avatar
Genopsyde Normal reputation
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
i'm guessin he has a 305tbi RS
1986 Fiero
1990 300ZX TT
1991 Camaro RS 355
1998 Tahoe 4x4
1999 F355 Spyder
Genopsyde is offline   Reply With Quote
Old 10-21-2004, 10:32 AM   #5
Hypsi87
I got your v-8 swingin!!!
Hypsi87's Avatar
Hypsi87 Normal reputation
Send a message via AIM to Hypsi87
for the GM OBD I cars, there is no chip out there that can give you that much gain alone. You should use chips to tune out your setup. Not to increase HP.
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Hypsi87 is offline   Reply With Quote
Old 10-21-2004, 12:20 PM   #6
89IROC&RS
89IROC&RS's Avatar
89IROC&RS Normal reputation
cheapest way to get a good boost of power is to get a set of junkyard vortec heads, and a SDPC tpi vortec baseplate, back to back dyno tests have shown 50hp increases at the flywheel. and thats with unmodified heads. take the time and money to have them ported and polished and setup for a larger cam, and sense youve got the intake and heads off anyway, do the extra work and throw a cam in it, and youll be off to the races with well over 300hp and have spent less than a grand. and depending on the size of the cam you get, you might even get better gas mileage.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
89IROC&RS is offline   Reply With Quote
Old 10-21-2004, 03:30 PM   #7
Dober89
Re: Re: more power for 89 camaro
Doesnt the SDPC base plate cost a nut and a half??
Old 10-22-2004, 01:52 PM   #8
89IROC&RS
89IROC&RS's Avatar
baseplate is somewhere between 300 and 400 bucks. but if ya get a pair of junkyard heads the combination isnt very expencive, and it does wonders for hp.
Old 10-26-2004, 03:09 PM   #9
BrakeTorque
BrakeTorque's Avatar
BrakeTorque Normal reputation
I dunno i would get heads polished and ports polished as well as get a Crane Cam and that should give you a good 100 horse for about 800-900
bucks
BrakeTorque is offline   Reply With Quote
Old 10-26-2004, 08:04 PM   #10
89IROC&RS
89IROC&RS's Avatar
the factory heads????? i wouldnt waist the money on em, for less than the price of a port and polish job, you could get a set of junkyard vortec heads which would still flow more air. then spend a bit more and get the baseplate. the port and polish job might be worth 20hp, the heads and baseplate are worth more than twice that, and if you spend the money on the cam, you would see even more hp from the vortec combo than the ported factory heads.
Old 10-26-2004, 10:27 PM   #11
BrakeTorque
you like thos vortec heads eh?
Old 10-26-2004, 10:40 PM   #12
BrakeTorque
I dunno ive just seen couple ppl get walked over with thos heads. And that you have to use the stock vortec intake manifold and the valves are pritty weak in them, but on the other hand they can hold a good 420hp id say. I dunno me personally would use holley becuase of the thick valves that work better under higher rpm's. Everyone has thier own opinion. lol my hole trucks pritty much holley.
Old 10-27-2004, 09:30 PM   #13
89IROC&RS
89IROC&RS's Avatar
well the thing about the valves, is that they arent limited by the heads, you can easily run 2.02/1.60 valves in them, so long as you get the 062 castings, the limiting factor here is his 305. the 350 runs a 4.00in bore, the 305 runs a 3.736in bore, that the 2.02/1.60 valves wont fit into.
and its not just me that likes those vortec heads, i have yet to see a magazine engine build up using vortec heads that didnt top 400hp with less than 10:1 compression and pretty mild cams. the airflow out of the box is already above the lower level bowtie heads, so their stats speak for themselves. oh and you dont use a factory vortec baseplate, SDPC specificly designed the baseplate to work on vortec heads, the intake ports are matched, it has increased volume in the runners to compliment the higher airflow. The intake ports on the vortec heads are so much bigger than the factory heads, the baseplate from the stock setup cannot even be modified to fit, because the ports of the vortec heads actually are higher than the edge of the baseplate lip, so you would have a quarter inch opening in the port to the head.
Old 10-28-2004, 07:56 AM   #14
Pewter'01SS
Pewter'01SS's Avatar
Pewter'01SS Has more negative feedback than positive
Vortec heads are the way to go. The runners have a rounder short turn, which means the air flows in a straighter path. The entire runner is a nice sweeping radius so the air doesn't have alot of restriction. The chambers disperse the combustion over the whole area of the piston. Basically, they kick ass. Plus they are abundant enough to be cheap. I just scored a used set for $140 a couple months ago. I'm going to mildly port them, have them machined for a larger cam and I'll have an awesome set of heads for around $200. Gotta love it.
R.I.P. Andy...It was an honor to have known you.
'01 Camaro SS - SLP Short Throw Shifter, Granatelli Air Lid, blue neon underbody kit
'92 Chevy 1/2 ton 4X4 - 350 w/ 190,000 miles and in desperate need of a rebuild.
'86 Chevy S10 - 350 w/ 400 Turbo trans, B&M Pro-Ratchet, 4.56 Posi, 350 is gone and slowly being replaced.
Pewter'01SS is offline   Reply With Quote
Old 10-28-2004, 11:09 AM   #15
89IROC&RS
89IROC&RS's Avatar
not a bad score pewter'01SS, i got my vortecs as a package deal, still bolted to the complete R code 350 they came with out of a 99 tahoe, 100 dollar core charge for the whole thing had everything from the oil pan to the valve covers, no intake though. have to love working at the dealership
Bookmarks
Google
Web AF
