94 Quest, Front Blower Motor Relay Locationmdion 10-20-2004, 05:39 PM I am trying to locate the Front Blower Motor Relay in my '94 Quest (DPST). I think I have it located just to the right of the fuse panel (inside left of driver) at the top of a column of 4 relays. HOWEVER, according to my Haynes repair manual, 1) the wire colors are not correct at the relay, 2) I do not have continuity to the correct fuses, 3) nor continuity to the blower itself. The relay pin numbers do match the Haynes manual. I think there is only one other DPST relay in the car (inhibitor relay, under the hood). This should be simple, but . . . Anybody know where the Front Blower Motor Relay is located in a '94 Quest? Thanks djgdjg 11-10-2004, 04:05 PM it is located behind left side of i/p insturment panel for a wiring diagram email me at redman@email.com hope this helps Fred Porter 09-07-2005, 06:31 PM 95 quest front blower doesn't work. Any one have a similiar problem and a fix for it. IH8SPM 11-02-2005, 09:30 PM Check for a broken ground inside the control unit. There are pics of this repair on another forum that something like villager forums or something like that. Automotive Network, Inc., Copyright ©2012
