Weight difference in S13's and S14's?Autofreefindersguy 10-20-2004, 11:12 AM I know the S14 's weight more, but does anyone know how much? Is their a link to specs on the cars anywhere? Thanks much. zauber 10-20-2004, 11:21 AM s14 3300lbs s13 2700lbs i believe that is right, but that is curb weight i believe. Autofreefindersguy 10-20-2004, 11:37 AM Thanks much, I was thinking it was a pretty good difference...Any links to a spec page for the 240's? TatII 10-20-2004, 11:43 AM S14's weights anywhere from 2800-2900 depending on trim S13's weights anywhere from 2600-2700 depending on trim. there is no way a S14 can weight 3200. if it did it would have a very very nice and stiff chassis, but it doesn't. its weak as shit. SHO411 10-20-2004, 11:47 AM 3200lbs!!!!!!!!!!!!!!!!!, it's listed as 2700lbs on the door, or 2900lbs loaded. billclinton 10-20-2004, 11:59 AM maybe he weighed it himself and is a sumo wrestler Autofreefindersguy 10-20-2004, 12:04 PM Well we should be able to check from a old write up when they changed to the S14? Like a Motor Trend write up or whatever? A link to a spec page? publicenemy137 10-20-2004, 02:18 PM S13 coupe - Typical Curb Weight: Manual: Base: 2699 lbs. SE: 2712 lbs. Automatic: Base: 2759 lbs. SE: 2772 lbs. s13 hatchbacks: Typical Curb Weight: Manual: Base: 2730 lbs. SE: 2747 lbs. LE: 2748 lbs. Automatic: Base: 2790 lbs. SE: 2807 lbs. LE: 2808 lbs. S14s - Typical Curb Weight: Manual: Base: 2813 lbs. SE: 2826 lbs. LE: NA Automatic: Base: 2875 lbs. SE: 2888 lbs. LE: NA And there you go, s14's don't weigh that much more. It has more safety regulations like side beams on the doors to make them safer, but weighs it down. Autofreefindersguy 10-20-2004, 02:29 PM Thanks much, I thought it was more then that... SHO411 10-20-2004, 03:14 PM you could try and loose some weight, this should bring the weight down, and also leave your over weight girlfriend at home till she weighs only 95lbs, then she can ride in your car. and loose the rear seats, we could hardly fit in the back seat of my T-Ram, so just go to those cheap motels $35 a night, but trust me, the open room works wonders on the back. vBulletin®, Copyright ©2010, Jelsoft Enterprises Ltd.
Automotive Network, Inc., Copyright ©2010
